2025 windows on the single cab
Frank22
I like everything about my Ranger except the power windows still wont go up most of the time without you having to pull to help them up--did I get a lemon?
My passenger side will go up pretty slowly if I haven’t given it a bath or had a good rain for awhile. But once it’s washed it goes up faster. The drivers side does go up faster, but still slower than I’d like. Definitely not faster than any of my vehicles.
I would say if yours is not going up all the way on their own, you need to have the dealer check it out under warranty.
Mine go up and down fairly slowly, the passenger side is faster than the drivers side for sure. It does matter if everything is clean, I also lubricated my seals which helped. Supposedly Polaris made some changes to the 2026 models to help this.
My driver side rarely goes all the way up by itself. Dealer even put new regulators on and no difference. They said to spray lube te seals and that helps but leaves a messy window and collects dust
I have a 2025, very slow and sometimes wonder if they are going to close all the way. Just another issue that Polaris does not take ownership of a problem!
Had the same issue on mine. Sprayed 3 in One RV Care Window and Track dry lube along both window tracks and then ran the windows up/down several times. They go up/down much better now.
