🔖 It looks like you are browsing the site as a guest. By registering on the site you can participate on the Internet's largest Polaris Ranger XD 1500 forum. To register, simply Click Here!
I'll bite, what is "torque limiting mode"? We've had ours nearly a year now and the manual says 120 degrees to drain it for the tranny fluid change, and I've never seen that high of a temp even in the heat of summer?
Manual says if transmission temperature gets to high, transmission will resort to torque limiting mode. I assume this means cuts power, de rate etc. Manual doesn't specify what that temperature is ?
