Window rocker switch
scudd
I have a 3 seater so there are 2 blanks where the rear window switches go. I wanted to wire up a bumper light and wanted to mount the new switch there. The only problem is that the switch openings are bigger so the normal rockers won’t fit in.
What are some solutions /options ?
There are so many options out there in switch size, not sure if you could google and find something that fits it. Are the openings already created? If not, could you remove the panel, and make the holes the size you need? Another option I kind of did on my previous truck, was buy a switch plate with certain size switch openings. And cut a rectangle hole in a section of my lower dash. You could always do something like that and make your own switch plate out of flat metal, that would fit where the rear window switches would go.
Thanks for the tips. I might try to cut the proper size out of a piece of plastic and fasten it over the larger holes.
