2024 Steering Gearbox
Sweaver24
Hey all,
I have a 2024 Northstar Crew Premium with approximately 5,200 miles. About a month ago I noticed a substantial rattle in the front end. After jacking it up and wiggling everything possible, I came up empty until I started the machine and noticed just turning the steering wheel slightly, that I could replicate. Anyway, Polaris warrantied the part, and my question is, has anyone else had this happen? Also, they said the steering gearbox was a $2000 item. Yikes!
This is the first I have read anything pertaining to steering problems. There is always going to be a small percentage of defective parts get out into the system, hopefully that's what happened with you and this is a one off. Glad they fixed it
Oh yeah! No complaints with the machine or Polaris. They also fixed the rear axle clunk and are flashing the transmission ecu.
I haven’t had any issues with the steering either. Just the annoying rear clunk. I’ve only got just under a 1K miles on mine though.
I have 8,700 miles on the unit now, and the rattle in the front end has returned. There is a note out from Polaris stating this is common on this model and they are working on a resolution. The rattle shows up just driving over bumps in the road. Anyway, still no complaints, just sharing an update.
Yes I have that rattle two going over bumps. I have a 2024 Polaris Ranger 1500 premium with a 10,400 miles on it no problems really
That’s impressive on the miles. Do you use it for work or just pleasure ride?
did u get that rattle fixed cause mine just started today if so what was the problem thanks mike
