Does anyone here have any tips/tricks for accessing the clock settings on the Instrument Cluster (which is the in-dash gauge cluster right in front of the steering wheel)?
The instructions appear clear. However on my 2025 RANGER XD 1500 NorthStar Edition Ultimate, the options cycle from: BL LEVEL / UNIT - Temp / Unit - MPH / EXIT. The CLOCK option never appears. Disconnecting (and then re-connecting) the battery did not change this menu sequence. It did, however, re-sync the IC's time with the RC's clock.
It seems I am overlooking something simple or the instructions are way off.
From Page (61) of 2025 Owner's Manual [9941778r01_web.pdf] -->
1. Press and hold the MODE button to
enter the settings menu.
2. Press either toggle button to cycle to
the “CLOCK” option. Press MODE to
select.
3. Press either toggle button to cycle to
the desired setting (12H or 24H).
Press MODE to select.
4. Press either toggle button to change
each segment of the clock. Press
MODE to accept a change and
advance to the next segment.
select.
