Front fenders removal
LOBRI
52761
Planning on removing the front fenders to add foam to block air coming into the cab. I've seen pictures of XDs with the fenders off but can't locate anything in writing or video that shows what is required to remove them. Anyone have any insight into this?
No point in that. From the front hood area with the hood removed. There are 2 holes the wiring harness goes through. Seal those two holes up with foam.
There are no other holes into the cab that leak air.
Thanks Clubin, I'll check those out!
