Loud bang when front suspension will become completely unloaded
Papa Hoc
Hey, everybody took the 1500 out for the first time this weekend and aside from the rear end clanking like it’s gonna blow up we had a blast. I have a question about the front suspension – if you go over something large enough to allow the wheels to become completely suspended in the air, there is a loud bang that occurs in the front end. I would assume it suspension just fully unloading and hitting the stops of the shocks, but don’t want to assume anything with this beast! Thanks in advance to all that author a reply.
Are you sure it's not the front tow rings banging? I had big noise in front end once I tightened the bolts noise stopped
If you look you will see the front tow rings have a rubber bump stop mounted on the bumper (at least mine does) it would be hard to believe this is a source of any significant noise.
Mine has rubber bump stop too hit the bottom of ring with your hand sounds like you hit the frame with a hammer really transfers the sound tightening bolt stops it
