plows
TOMDAN
Does the 2026 XD-1500 plow frame (Pro Series Plow Frame
Item #: 2891553) fit the 72" plow blade (Snowplow Blade
Item #: 2890335 ) from a XP-1000?
I don't see how it could. If you look at the back view of the 84" blade, it has a bent up support tube in the middle, and this is needed for clearance to the frame. The 72" has a straight support tube. There are also 4 vertical webs on the 84", and the frame mounts between each pair. The 72" only has two webs.
I had both and agree with jj46, mixing the parts will not work. You can however mount the XP1000 plow and frame to your XD1500. The plow mounts fine but the XD sits higher than the XP so your plow will not be very level when you angle the plow.
