Squeak
JCLND
ND
anyone had a squeak from the front dash or possibly windshield area? if so what was it? i’ve got one and it drives me nuts. Outside that the machine has been amazing in every way. Thanks guys!
Mine did it. It was the front glass against the rubber seal. I put weather stripping foam between the two and it solved it. Both my Ranger XP 1000 Northstar's did it too.
That was going to be my first shot at it……thanks for the info though. can i ask what you used specifically since it worked for you? do the entire frame of windshield ?
Hardware store weather stripping. Adhesive on one side. I know along the bottom I used 1&1/2 inch wide 1/4 inch thick. On the sides and top I believe it was 3/4 inch wide.
