AUXBEAM Light Controller
awickedtruth
There are only a couple things that I do not like on my Texas Edition... one being the limited amount of space for switches. On my General I had installed an 8 Gang Auxbeam Switch Controller but on the Ranger XD there is only one opening on the dash panel and I did not want to run all the wires to the overhead console. I did not know that Auxbeam had come out with a slim version. I measured and found the Slim 6 Gang Switch Panel (AS-R60) fit perfectly in the overhead switch console. I recently installed an found it was easy with zero holes needing drilled... Remove the switch for the back up light (you can reroute and control them with the Auxbeam) and all the other hole covers. The slim switch fits perfectly in that place and allows you to add up to 6 more items and you no longer have to run them into the cab... they all wiring under the hood. Looks good and works great.
That looks great... clean. And if I am correct, only one wire needs to be ran to the control panel, yes?
Yes.. single small cable... fits easily thru the grommet behind the gauges on the firewall.
Looks great, thanks for posting.
