Suspension
Luv2hunt
Does anyone have suggestions for a softer suspension is there one available?
Did you double check and make sure your shocks are set to the lowesi setting. It seems to me it rides and handles pretty good for a heavier machine.
I agree with what Jeff said, I feel if it was much softer than the lowest setting you would lean over more in corners and on hills which would make it feel less stable. What tire pressures are you running? You should be able to easily run them as low as 15 psi which will make it feel softer.
