Air Conditioning
Rooster2
My 2024 Ranger XD 1500 air conditioner doesn't seem to cool as well as it should. I was told that there is a Schrader valve that could be causing this issue.
A Schrader valve is a fill port for the A/C system, if it is defective it will allow refrigerant togg escape the A/C system. Are you capable of servicing the A/C system? If not you will have to take your machine to someone you can check you A/C system out.
You can wet your finger with some soapy water or saliva and put it over the ports... you should be able to tell if it's leaking... that is, if there's any left.
Thanks DC for your response. I have added refridgent to the AC , but still feel it should be cooler. And after approximately two hrs of run time cooling is definitely a lot less.
Take it to sombody who has the proper tools. The system is critically charged meaning it requires an exact charge to work properly. You can’t just add refrigerant to it and hope it works. It’s not a guessing game.
