center seat belt
Oklahoma 1500
Has anyone come up with a fix for the center front seat seat belt rattle yet. It is intermittent and depends on engine vibration and or rough road. but every 1500 has it. just hit the rear seat grab bar right behind the front center seat belt retractor to hear it.
Well I have never heard the "front seat seat belt rattle" yet so I can't speak as to how to fix it. Is this a problem unique to 4 door units?
I plug the middle belt into the driver buckle. No need for a bypass
But plugging it in has nothing to do with the recoil box rattling on these. all the recoil boxes do it but the center one on the front seat does it the most because it gets more vibration from being bolted to the rear seat grab bar. But all recoil boxes should be re-engineered by Polaris or their vendor.
It must be a 6 seater problem, like I said before I have no rattle
The 6 seat version has 3 big recoil boxes for the seatbelts in the front row and all 3 rattle like crazy. My dealer told me they submitted a case with polaris about it.
I have the same issue when I first accelerate, and then it's gone.
I don’t have the seat buckle rattle or the under dash rattle but I sure have the clunk. Mine is a 2 door April 24 model.
Same, I know I don’t have the seat belt rattle. Haven’t had time to check for dash or windshield rattle yet. But haven’t noticed anything significant in those areas.
My 2025 XD NS Crew is the same way! However, it sounds more like it's on the passenger side rear area? Almost like a tin heat shield of sort vibrating???
Mine has the center seat belt rattle. I removed it to verify and haven't reinstalled it yet. Mine is a 6 seater.
In my 6 seater I found that the handrail bar that the front/middle seat belt housing is attached to doesn't have a center support so it's like a tuning fork and rattles the heck out of that seatbelt housing. I've got a ratchet strap connected from that bar to the seat frame and it took care of the rattle. Some day I hope to fab up a bracket to replace the strap but for now it's quiet.
I tried to fab a rubber isolator to fit in between the bars but couldn't find exactly what I wanted to make it look factory. For now, the seat belt is removed but I don't want to leave it that way.
