Washing lower door plastic remedies.
jeffrey Burnham
Good afternoon Polaris Ranger 1500 XD owners!🇺🇸 Anybody here find the correct method of washing/cleaning the lower door plastic back to its original color. I’ve power washed before and after hand scrubbing with dawn dish soap and I can still see the spray lines of the power washer. Maybe I’m not putting enough elbow grease into it but thought I’d see what you all do to combat this issue. Thanks in advance!✌🏻🇺🇸 (Edited) now that I’ve posted this I’m finding different ideas on here for the question I asked. 👍🏻
I first rinse the Ranger off, then I spray with a foam cannon, then I use a washing brush to to loosen the dirt. I rinse off, blow dry with Milwaukee blower, and final wipe with a terry cloth towel. Easy peasy never a problem.
I should also say that I use an AR Blue Clean TSS electric pressure washer, not the cheap one the industrial one running on 20 amps. My set-up runs around 1050 psi with a 4 GPM tip which is about what you want for washing cars. I never use my gas pressure washer on my vehicles as it makes too much psi for the task at hand. So long story short I'm not forcing the dirt off with a bunch of psi, I'm letting the soap do the work of breaking it down so it rinses clean.
For the bottom black plastic, you could always use SC1 to bring back that shine and new look. Or what I’ve done, is bought the Cerakote brand plastic trim wipes from Walmart and applied. It last quite awhile.
I use amsoil mudslinger. Brings the black back to life and puts a film on it to keep mud, dirt, and grime from sticking. Works great.
