Aftermarket Assassins exhaust 1500 ranger
Gimli Manitoba Canada
One primary muffler. Two secondary mufflers one with the internal guts blown out. One new.
Don’t want it any more. Shipping will be paid by buyer.
$1100 cad
Fits all 2024+ Ranger XD 1500 Models (Single & Crew Cab)
This AA Dual Suppressor stainless steel slip-on exhaust is just what your machine needs! We set out to produce an exhaust that looks great and sounds great without being obnoxiously loud.
Dual muffler design links 2 mufflers with a v-band clamp for easy installation
With our dual muffler design, this exhaust sounds amazing with a nice deep tone but not louder than the OEM exhaust. At idle, off idle, and wide open throttle you will notice a tiny bit more rumble/lower exhaust note. When cruising, this exhaust is as quiet or quieter than the stock exhaust. The deeper tone helps cover up some of the engine noise/drone. You will love the sound.
Includes a removable 2" spark arrestor
Gains a massive 7-8 RWHP (10 crank horsepower) and gains a ton of lower RPM horsepower/torque compared to a single muffler due to the increased volume.
Much better airflow which is needed to decrease heat
Eliminates the stock catalytic converter which creates a ton of exhaust and motor heat
Fits nicely into the factory location and allows the bed to dump fully
Made from stainless steel right here at our facility in the USA
Tumbled to a lightly polished finish that looks great!
Can be used with the factory tune or our Level 1 tune without issue but will run even better and gain the most power with our Level 2 tune designed for this exhaust.
Decibel Readings(Same as OEM, but a better note):
OEM Exhaust: 77-79db Idle / 87-88 db @ 4000 RPM
AA Exhaust: 77-79db Idle / 87-88 db @ 4000 RPM
