Reverse Alarm/light
mhhman
Monroe, UT
Does anyone know if the XD has a pre-wired reverse beeper plug installed? My 2020 Ranger had a reverse beeper plug from the factory.
You could look at the install instructions for the Polaris reverse beeper (I think they offer one) it should tell you how to install it and it would show you if there was an additional wiring harness required.
It would be a simple mod,
Install a relay near the battery with a fused hot to it.
Run wire from relay to beeper, ground as well of course.
Find back-up light circuit, tap into it and run wire to relay trigger connection.
