Running tracks and adjusting speedometer and odometer?
Gimli Manitoba Canada
On my 20 ranger I bought a speedo healer it was set to 40% to adjust for the tracks. Is there any settings in the 1500 that allow you to do this?
I run tracks a good part of the year. If I don’t adjust the speedometer it racks the miles in so fast!
I haven’t seen any tracks for the 1500 besides the dura clutch brand. Which is a little rich for me for how little I’d use them. Doesn’t look like camso or Polaris have any available yet.
I have a set of Mattracks I had on my xp1000 that I bought the conversion kit from Mattracks for the xd 5 bolt.
I just sent these guys a email. They’re the guys I always used.
Email from healtech below. Any one know where to access an online service manual?
We don’t have direct experience with this model and don’t have access to the wiring diagram to confirm compatibility.
If you can send the full Electrical Wiring Diagram/full Service Manual of the Ranger 1500 we can take a look and advise. Maybe your local Polaris dealer could help with that.
Kind regards,
/Attila
www.healtech-electronics.com
I sent them a pic of the wiring diagram from the shop manual. This is what came up. I just ordered is and can not confirm it works. When I get it and install it. I’ll let you know.
The stock 30" tire at 65 mph should read 65 mph, if you jump up to a 32" it will actually be doing closer to 69.33 mph. I also have the 32" BFG KM3's and they are likely more than 2" taller than the stock tires. That said at full throttle I'm sure I'm going at least 5 mph than what my speedo says, I confirmed this with a GPS several months ago. You can find calculators online that do the math for you.
Please update with results. I'm on tracks and would like this to work
Here is tire diameter calculator from Interco :
Well. I installed it. Set it up for 60% reduction.
This is what I can report. Speedo read as normal. It does not start good, check engine light came on, and I got a power steering fault. I power cycled the key a couple times. Tried it again same results.
I disconnected the wiring harness from the ranger and cycled the key. Restarted it it started fine, no fault codes. I’ve sent an email off to the manufacturer, I will see what they say, and report back. But as of now, I would say this is not going to work.
Thanks Cubin, I was interested
