Power Drain killing battery
Moman4u
Hi
I did search for wiring diagrams but couldn't get any answer to my issue.
I have a heavy drain wich seems to killed my original battery. I purchased a new one and noticed it just now. I did the " pulling all fuses" etc but didn't find the issue. Next try was the alternator but it's a NO also. Then i disconnected the the wire on the positive terminal, the one on the right m6 with a 10mm nut if you look at the terminal. And that turned my test-light off. No my question is we're does this leads to? It disappears in a big fat harness. Seems to be without any fuse etc.
Does anyone know where it is connected to?
Thanks
Rolf
I would like to help if I could but I find your question very hard to understand.
Looking at the batteries positive terminal you have several connections, the one with the main fuses, then 1 wire on top on the left of the terminal and a second one on the right with a 10mm nut on a 6mm stut. Thus wire is the one withe the bad drain, I was like to know where its leads or connected to.
