bchar11
SB339 vote 1/13/26Will be watching
Vote on 1/13/26If u are in Wisconsin it is looking good for a increase to 3500.
Look for Wisconsin SB339 AND AB327
Assembly voted on and passed Senate Bill 339 today on a voice vote. It will be sent to or be requested by the Governor in the next few weeks to sign or veto.Vote on 1/13/26
Governor has 6 working days if does not veto bill it becomes law with no signature . He could sign sooner or veto sooner. Hopefully a good outcomeAssembly voted on and passed Senate Bill 339 today on a voice vote. It will be sent to or be requested by the Governor in the next few weeks to sign or veto.
I had heard that MN Was looking at 3000 and the decided to hold off Polaris told them they needed to look at 3500 they wanted to see what happened in Wisconsin.Some comments about Minnesota's 2000 lb limit. There was a bill introduced in spring 25 to increase weight to 3000 lbs.... it died immediately, went nowhere.
My biggest concern: When you purchase it, the dealer absolutely will register it as a Class II ATV... ok, cool. They got around it in the past by using the dry weight of the stripped down, no doors, no hvac, non-Northstar version of the 1500. Now, Polaris doesn't even offer this trim level... they are all Northstars.
IF you get caught by an overzealous DNR officer, your ATV registration is invalidated and you must re-register as an ORV. Once you do that, several things happen:
1. You can't ride any ATV trails, ORV only which extremely limits available trails.
2. If your city/township allows you to ride ATVs on the streets like they do where I live, this will be invalidated and you can no longer ride on roads.
3. Once the VIN is registered as an ORV, it can never be converted back to an ATV registration, unless that was included in a proposed bill that passes (unlikely).
These machines are not inconspicuous.... they are extremely obvious and easy to spot. If the DNR starts cracking down on full-cab machines, anyone with Xpeditions, Ranger 1000 Northstars, 1500s, HD10/11s, etc are screwed multiple ways if they want to ride off private property.
At least it looks like it may change soon. But I have hoping for whileI consider myself lucky that Iowa has no size or weight limits on their SXS's. Other than the 35-mph speed limit and that stupid SMV sign I don't have much to complain about.
Still waiting to get to the governor when it finally gets there he has 6 days to sign or veto if he does neither it passes anyway. The odds at passing appear to be around 85% i will post when I know the outcomeJust curious if this went through or got vetoed
Thanks. I'd like to go on a trip up there.Still waiting to get to the governor when it finally gets there he has 6 days to sign or veto if he does neither it passes anyway. The odds at passing appear to be around 85% i will post when I know the outcome
Hopefully soonThanks. I'd like to go on a trip up there.
It is official wisconsin increased to 3500lbs dry weight. Takes affect 1st of MarchIncrease it from what to what? My 2 door weighs around 3000 lbs so they will need to go to 3500 for a 4 door. 4000 lbs would be better because I'm sure some here are close to that by now.
It is official wisconsin passed weight to 3500lbs governor signed. Takes affect 1 marchThanks. I'd like to go on a trip up there.
Passed 3500lbsKeeping fingers crossed, thanks for the update.
It passed 3500lbs takes affect on 1 marchYes Wisconsin is looking to increase weight limit.
Passed. 3500lbs 1 MarchSB339 vote 1/13/26
