oneal
- #201
That is so disappointing, I hoped they had figured it out with a solid cure.I got new axles and the dealer applied loctite to them. Let it sit for a couple days to let the loctite cure. My machine still clunks. Not as bad as it was, but it’s still doing it.
0ne detail that still doesn't make sense on JUST an axle replacement. The excessive tolerance of the splines is either the axle diameter is too small , the hub bore is too big, the splines are not equally cut, or a combination of both.
For folks like yourself that have lived with the clunk for numerous months and the clunk noise emits from the male and female spline banging back and forth I feel it would wear on the outer spline as well which is the drive hub. I anticipated the "clunk cure" would be new axles and hubs.
Loctite is meant to fill gaps of SLIGHT tolerance issues, I think the reason it worked for me and a small handful of others is because it was applied early before the splines had time to wear on each other.
